Anyone tried that LMS sniper tune?
Special Forces will data log and tune EEC V gas vehicles. Data logging does not include a/f ratios but note lap top is required for data logging.
Tweecer RT will tune and datalog EEC IV cars
Heck most units out now days have functions as both datalogger and flash tuner. Just because the same electronic device can do both jobs does not mean those two jobs are the same. As I said before, two totally different animals; Datalogging and Tuning. You are a SCT Pro Racer, you should know this.
Yep, most logging and tuning devices have the ability to configure 0-5v analog inputs for such items as MAP sensors, EGT, AFR (wideband), fuel pressure and so on. Those will be the ports through which a person will configure their logger and the software to accept the wideband AFR meter analog outputs to read AFR's on the datalogging screen with all other read parameters. As with most all logging/tuning packages offered the wideband to read AFR's is a separate purchase item.
Is what you purchase just the blank tuner or does it come with custom tunes (programs) for your car? If so who does this, Sniper themselves or is it an LMS tune?
How does it compare with the program tuning offered by Lonnie and Torrie?
YOU make the tune yourself, no blank anything, YOU build the program and flash the ECU YOURself. Please read this.
Old thread alert.
The SniperTuning.com website seems to have changed, and no worthwhile info is available. What happened, and where can I get online info regarding their tuning products?
Edit: Well hell, I found their new deltaforcetuning.com website. The homepage works, but all the links lead to what I think is dead PHP script. (I wonder how they can make a tuner but not a website that works...)
