(HELP) 93 mark VIII shifter stuck in park
newguy
chicago
and it will only go out of park when I disconect the battery?????????ANYBODY??????? is there a sensor under the brake pedal that mite be bad or came out of ajustment
Brake safety switch could be bad, I had to replace one on my Wife's 00 Stang. It would fail to work on any incline, after rocking the car back and forth it would kick in and release the gearshift. Finally it failed 100%.
Man that sucks. I mean a lot can go wrong with a car, but that? lol. everything is good and you just cant get it in gear. Any way to bypass it?
I thought this mite be a common promblem,or there is a switch for that,maybe under the brake pedal??like the brake light switch
look for a broken wire at the brake light switch, and on most fords if you turn the key to the first position you can take it out of park then put it in neutral and start it from there
thanks
yes thats what I'm doing now,also my radio don't work,,but makes a cracking noise when I was sitting in the car last night(with the key off) reading my dealer bk
doooooooohhhhhhhhh
Im dredging up an old post because my car is now having this problem. It takes quite a few presses of the brake pedal to get the shifter out of park. Is there anything other than a fuse that could all of the sudden go wrong???
like chicken said....brake pedal switch....replaced twice on my sho dur to the same problem, one went intermittently out, the other just outright died.
Turn to the first key click and go to neutral, then start.
thank you guys . you help alot . it was a wire that came lose on break peddle switch ... !!! my break lights are A ok and my sifter is now working good .. thanks again guys ...
