i got a tool similar to this from autzone but its got a handle attatched to it that swivels, i can get it on there, but there is no room to turn it anywhere. Are you telling me you did this both in an hour with out dropping the exhaust?
i see that this would be easy if the tool had a swivel and ratchet attatched to it - but theres no way you can just use the autozone 22m 02 sensor tool with a gen 1, with out dropping the exhaust... believe me i was under the car with the tool flipping out.
gotta go 22m crows foot swivel and extension with ratched while using a mapp torch to hit up the bung, its going to be nice out tomorrow so i cant wait to mess with the mapp torch.
btw anyone know any local tool or parts store that carrys that tool - or even a 22m crows foot? i cant find it anywhere.
again also for the drivers side, did you go throgh the top or bottom, because the cat on the drivers side from the bottom has some wierd pipe with a big nut coming off of it going towards the engine that gets in the way and also the steering knuckle - passenger side looks easier as there is not as much stuff in the way. but its tight and i could barely get that autozone tool on there, and when i did - again no way to untorque it because the handle hits stuff - NEED A RATCHET DEVICE. So the crows foot or that tool above is absolutly neccessary.
