turborich
My alternator works fine however when it's cold in the morning & I start the car it has a high pitched bad bearing sound to it. I want to take it apart & either lube or replace the bearings.
Is it as simple as removing the front nut & then the bolts that hold the housings together? I know about the brushes needing to be held in with a paper clip to put it back togeter, Is there anything else that I'm missing?
Thanks, Rich
Thanks, Rich
