2000LSMichael
I copied this pic from an earlier post and would like to know what the parts are that I have circled. I am getting to know the LS a little better after only a few weeks.
The fuel pressure regulator is the mechanism at the other end of the tube---attached to the fuel rail. To the small extent that I've played with it, it seems to sense pressure and tell the fuel pump to 'step-up' the pressure because of demand.Okay, left to right:
Throttle Position sensor (TPS)
Vacuum line
Exhaust gas recirculation (EGR) valve
Last one... I'm not really 100% sure but I think that's a fuel regulator of sorts
And for reference... what is listed as the degas bottle... is not the degas bottle. The degas bottle is the over-flow tank for the radiator; it's where you pour in your coolant.
