thanks for everyones help, just also wanted to ask where I can buy the control to lower my car. thanks
i agree the headlight and the pin striping are the number 1 priority after I fix the airbags, I don't like the gold stripping thank god its only a stick on and not painted on. thanks for everyones feedback.
Nice Mark. I love that color.
Is it me or does your car look too high?
I'd make sure that the air ride is working properly before installing the Module though. A spider valve works well with the Module too.
I've got those modules on both of my Marks and I think they're great.
I will do that tomorrow, I know that when i turn the car on the air system always turns on and lifts up the back about 1/2 an inch, it doesn't Sag all the way down in the rear at night but it does sag about a 1/2 inch I will test the bags for leakage this week. Thanks for the help.
It seem like it was higher to me too. the car actually always sits higher in the front than the rear even when the engine is off. . Any suggestions on what I can start checking, or how i can deflate the system and let it build back up?
Sounds to me like the front bags aren't venting. You said that the back will go down a small amount (sounds like parking height for the back), if the front isn't moving at all, and it also seems like it's a little higher, I think I would check the air solenoids for the front bags. They could be sticking shut.
