G
GrayGhost1
Guest
One of my customers bought a Wings West kit for his 04 LS. He is a body man by trade and said that he can make it work. He has supplied me with the initial pictures before installation. The pictures you see are of him test fitting the WW body pieces to the car. Below are his remarks regarding modifications needed for the WW body kit to work on the 03+ LS. Now, the WW front air dam may not be as easy to modify on the 04-05 LSE or the 06 LS. However, the side skirts and rear air dam would be able to work.
Let's discuss the possibilities for this kit on the 03+ LS. Thoughts?
Ok Ken
got this kit today and put it up against my car.
The side skirts require no modifications other than the usual fitment.
The front air dam needs a small trim on the outside of the fog light as you can see in the picture.
The back skirt requires some trim for the muffler tip to fit due to the larger 03+ opening as well as the muffler tip has to be cut and extended or the heat will melt the skirt.
I'm going to be doing this instal in the spring but this is what's required for the gen 1 kit to fit the gen 2 car.
I'll send some better pics when I instal this in the spring but I'd appreciate if you sent an aknowledgement telling me what you think as I'm sure these pics will help you sell a few kits till then.
If you like you can use these pics on your site.
Thanks Dan
