Lownslowlsc
It appears to me that they simply just add a mounting plate and maybe a harness connecter that is only for ease of install. Take a look:
vvv Looks cheaper than the other one and you simply just tap into the factory wires + - before the ballast.
http://cgi.ebay.com/ebaymotors/LINC...ryZ33710QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
vvvv looks abit higher in quality than the first but still looks to be the same design.
http://cgi.ebay.com/ebaymotors/Linc...ryZ36476QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
vvv Cheap "anycar goes" hid conversion, same exact setup as above 2 meant for mk8's minus adapter plate.
http://cgi.ebay.com/ebaymotors/HID-...ryZ36476QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Could there be anything bad doing what the first guy did? Essentially just cutting the "harness" that would go to the oem socket type, And splice those 2 + - wires in to our oem 2 wire harness.
The second one is pretty much the same but he has a socket at the end with 2 wires for looks.
I'm liking the idea of making my own adapter plate and buy one of the cheaper hid kits when mine poop out
Does this all make sence or did i get to far ahead of myself?
