02V8Sport
So I have a bearing grinding type of sound when going above 30MPH on right hand turns. I thought this could be a LH wheel bearing since weight shifts to the LH side around RH curves. I had a new front LH hub put in, noise is still there. Had a new bearing put in the LH rear, noise is still there.
I just ordered a spare RH rear hub and will get a new bearing pressed in and use my good LH front hub and put it on the RH side to see if the noise goes away. What else can this noise be?? Someone help!!
There is no noise going in a straight line.
Searched but found nothing like this, or at least a solution.
