Lincoln Mark VII Brake parts
Monnette
Stockton
I am having trouble finding these parts
Brake accumulator
ABS fluid pressure switch
Hydraulic pump relay
Can anyone help, I posted my problem on the welcome wagon section on this site if you need to know why I need these parts
Thanks
Monnette:D
Monnette, do you definitely need all of those things? Maybe better to just get the cheaper and easier to replace bits first?
The car went to the Garage this evening, I will not know until sometime tomorrow what is exactly wrong. I was just wondering about the availability of those parts. I called the parts store and they were no help, the Lincoln dealer was of little help and what he did tell me wasn't cheap and 1 part was actualy discontinued.
Those accumulators appear to be easy to get. (although expensive!) As Joshmcmadman says, junkyard for other bits, unless the garage can point you in the right direction.
The ABS system on these cars is quite unique. To be honest, most shops don't know anything about them, and almost always want you to replace a lot more than what is actually wrong. I strongly urge you to diagnose it yourself, which can be done easily with a little help from these articles:
http://www.lincolnsonline.com/tech/00021.html
http://www.lincolnsonline.com/tech/00188.html
