help me out real quick b 4 i order.
00_slow_5spd_ls
Bristol, Rhode Island
hey guys. I have a vacuum leak under neath my intake manifold. i am going to be
intake manifold gasket
pcv hose
pcv elbow
oem spark plugs
and fuel filter
is this what need?
Description Qty MSRP Price Your Price Core Price Total Cost
OEM Catalog
Fuel system Fuel induction Intake Plenum gasket LS6 $19.17 $15.45 $0.00 $30.90 Delete From Cart
Mechanical Catalog - 2000 - Lincoln - Ls
Emission system, Pcv valve, Pcv valve, ls6 $16.02 $8.94 $0.00 $8.94 Delete From Cart
Maintenance and lubrication, Engine service, Filters, Fuel filter, Fuel filter, ls6, ls8
i know i need 2 sets of the gaskets. and i also need the part num,ber for the oem plugs
The intake manifold gasket kit will come as a complete set with gaskets for BOTH sides. You can't exactly replace just one gasket since you have to remove the ENTIRE manifold (which will screw up the gaskets on both sides).
do i have the right part numbers? i called team ford but they were closed.
i need
intake gasket set.
pcv elbow hose
6 oem spark plugs
pcv valve
fuel filter
anything else i should do while im in there. all coils were replaced last summer.
aren't the intake gaskets on the V6 similar to the V8 - reuasable o-rings....?
