From what I understand, the EBC Greens are similarly low-dusting pads.
QUOTE]
I have the EBC greens on the front with Powerslot slotted rotors and they dust heavily! I dont think it is due to the slotted rotors but it could be. The factory pads and rotors began to dust heavily toward the end of their life. I have no indication of a dragging pad (car tracks straight and no pulsing while braking) so the only conclusion I have is the pads. They also squeal during about 50% of stops.
I will be trying the Porterfields with my next purchase.
+1 on the porterfields - no dust and I'm on my fifth set now.
for wax here - > http://www.wheelwax.com/
Where did you guys get your Porterfield pads from?
AFAIK, Porterfield is the only source for Porterfield pads. http://www.porterfield-brakes.com/Where did you guys get your Porterfield pads from?
I tried a couple of different ceramic and finally went to get dealer OEM pads.
The ceramic squealed every time. I can't stand the squealing. The OEM don't squeal but do dust. Do the porterfields squeal?
ok i have a stoptech stage 2 brake kit and it has the axxis ult brake pads and it causes a lot of dust so i was wondering to keep my rims from messing up is there a way i could buy something to keep it off?
I paid $126 for the set - I believe that is with the LLSOC discount.
all 4 corners.
QUOTE]
I had Green stuff pads on my wifes S-type (same pads/rotors as my LS)and they squeeled way more than 50% of the time. I got the shims from EBC and that helped ....for about a week then it got worse. I ended up putting Akebono pads and they stop and sounds perfect. I'll be using them on my LS when I need them. My $0.02
only problem is I asked for my old Green Stuf pads back and never got them - I was gonn send them back as EBC offeres a warranty with their pads.
FWIW I have a friend that had green stuff pads on his Cobra and they were fine - this was just MY experience
A
