mespock
Marxists - Socialists
even Autozone wires work fine.
Ahhhhh!!! don't say that please don't say the A word... I respect your opinions so much... I'm going to have nightmares now for months.
Yeah AUTOZONE kinda sucks, not so much their parts but rather their employees who just don't have a clue in most cases. There wires do carry a lifetime warranty though. Not sure if you will ever need to use it on the wires, YOU WILL have to use it on anything such as an alternator, waterpump, starter, etc!!!!!!!! Junk. They do carry a bunch of crap for the ricers though.
I am currious as how well these nology wires work as well. In the past I have never noticed an improvement from a properly working stock wire vs. a high performance wire such as an accell, msd, etc. Just my 2 cents.
PS remember the ohm's of resistance factor too, ohm out your favorite wire then ohm out a Nology, you will be blown away. Less resistance = more stable and consistent spark and longer life of the coils too.
Geno, could you take a Nology wire and hook up an ohmmeter lead on each end and let us know what resistance you get please, as well as the length of that wire? I'm curious about something I read on the Nology website...
Thanks
Geno, you sell the things. Of course you're not going to say anything that would hurt sales.
IMO, the only thing any of us need on these motors are stock coils, any wires, plugs of your choice. $200 wires aren't necessary even if they do work, MSD distributorless ignition systems aren't necessary, aftermarket coils aren't necessary, and MSD/Motorcraft/even Autozone wires work fine.
IMHO - the likelihood of a $200 set of plug wires being any "better" in your average Mark VIII compared to a new set of lifetime warranty autozone plug wires is EXTREMELY small. The likelihood of increased mpg because of a set of Nology plug wires vs just a normal cheapy new set is probably even smaller. Lots of manufacturers and resellers make all kinds of claims, and most of it is BS. Horsepower and fuel mileage has infinitely more to do with your engine combination and tune than it does what stupid plug wires you run.
Paul.
...Rich your correct about not feeling a difference with Accell, MSD..etc. quite simply because those wires typically have anywhere from 600-1500 ohms per foot of resistance and do NOT have any spark boosting capabilities where the Nology Wires have 300 ohms per foot and delivers a boosted spark.
Also when you go too low on ohm's per foot you start to get a EMI (Electro Magnetic Interference) effect which you will hear in your radio..etc.
Now MSD does offer as well as Moroso a low ohm wire but you will get that EMI problem and you will also not really see a difference in spark intensity between them...
Hey if you had a broken plug wire, had to go to work in the morning, and that was the only place open... you just might have Autozone/Duralast wires in your car too.
OK I guess in a last resort you may have to go there. Did they have to ask how many plug wires does a V-8 use?![]()
I'm sorry... I'm on a mission from god to trash AZ as much as I can.:shifty:
It's the morning and I still respect you...![]()
It's not BS at all. I as well as many others have gotten better MPG from these wires. As for the Junka$$ AZ & Pep wires, thats it they are junk, TERRIBLE resistance..etc. Watch how many times you replace them.
How is a 100,000 watt spark NOT going to be better then stock, and inturn give you better MPG because of the hotter spark burning more then the usual af mix in the combustion chamber.
Never thought I'd say this, but thank you Paul.
Without a properly controlled, well-documented, and independent scientific test (which isn't going to ever happen I'm sure), I don't believe that claim for a minute.
How the hell does a plug wire change the amount of fuel being metered into the cylinder? The answer: It doesn't.
$200 for a set of plug wires on a daily driver is outrageous.
Paul.
What are you talking about metering the amount of fuel? Who ever said that? I said it's a HOTTER spark therefore burning 98% or better of the combustion chamber contents?
You have no way of determining what percentage of the air/fuel mixture is being burned by the stock ignition system (and I bet that Ford probably put a couple dollars into engineering the flame pattern in the combustion chamber) or how much "extra" is being burned by the magical Nology wires.
Furthermore, how does a hotter spark = more gas mileage? The same amount of fuel is being metered into the combustion event regardless of what spark plug wires are on the car.
Paul.
Paul.
Yeah but if it's not all burned then????
A hotter spark burns more and more efficient wether its Nology, MSD? ANY hotter spark will burn more. The Nology's produce a 100,000 watt spark, thats pretty damn hot.
