01 Lincoln ls fueling issue
jtstein98
illinois
2001 Lincoln ls saved it from the scrap yard, fixed the coolant leaks and now trying to resolve the fueling/hard starting issues. If the car sits overnight it will start right up but. If it sits for an hour or so it will crank and crank about 5-6 seconds before starting and it will smell very strong of raw fuel/ car smells rich while running. So far I have replaced: fuel pump and filter, fuel rail pressure sensor (fixed the code for that) pulled all fuel injectors ultrasonic cleaned and tested them all and worked fine not leaking, new spark plugs, cleaned IAC and MAF. All to no avail car still has the same starting issues… running while using forscan there are no misfires and fuel pressure reads within range cranking and while running. There are no codes currently issue is so consistent it makes me think a bad sensor but without a codes showing I’m at a loss. Any ideas appreciated!
You did good troubleshooting. Can you post what your fuel pressures are?
The symptoms look like the injectors are leaking fuel after shut down but you had them serviced?
Try this? After it sits an hour when starting push the gas pedal to the floor and hold it there. This will shut off the injectors while the engine is cranking. Any difference?
What did the fuel filter look like that you replaced?
Replying to close this one out and “solve it” for anyone having issues in the future. It absolutely was an injector leaking… STILL. I cleaned and flow tested the original injectors and they passed re installed and shortly after one started to leak again causing the same issue replaced them all and AGAIN same issue. Bore scoped each cylinder and found one of the NEW injectors was leaking ‍♂️ replaced that injector and now issues resolved
