Electric fan conversion cooler line questions 1st Gen
00LincLS
Columbia
Question about an electric fan/hydraulic pump delete install for a 00 LS V8.
With the old hydraulic system there are 2 cooler lines attached. From my u the hydraulic system utilized the cooler.
What do I do with the cooler line?
Also, the auxiliary cooler, is it separate (since the new fan is electric) or do I need a new one?
And, do I need to plug the return line to the cooler at the cooler?
Any clarification would be appreciated. Kinda confusing atm
I swapped my hydraulic fan system for electric using a Derale fan shroud, a couple of Perma-Cool 19111 fans, and a proform 69595 fan controller. You can remove the hydraulic fan pump, reservoir, and the lines, and then you would just need a shorter belt to make up for the missing pulley. I have been running this setup on my '00 3.9 for more than 3 years without issue. One thing to note, these cars only have a 110 amp alternator, a lot of aftermarket fans can put a huge load on the electrical system, so be mindful of that.
Somewhere on the LS section of this page is a writeup where someone else bypassed their hydraulic system and gave the correct length belt for the job, if I come across it again, I'll let you know.
Also, just to be clear, the hydraulic fan system is completely separate from the power steering system, contrary to what many believe. Removing the hydraulic fan pump only affects the hydraulic fan system.
I know the system is completely separated from everything else. I already have the pulley and belt etc. What I’m asking about is the cooler lines. You have to remove a couple of cooler lines in order to do this job. Do these cooler lines get cut off and not used, do they get reattached, etc.
It’s not the electric fan, belt, pulley, controller that I’m concerned about but these cooler lines.
Just remove the lines. If you are getting rid of the other components, you could remove the lines as well. Alternatively, you could try tucking the lines out of the way if you didn't want to mess with disconnecting them at the pump. Unless the cooler lines you mention are part of a different system, and that's where you're stuck, there's really nothing to it.
My hydraulic fan system only had 2 lines total, feed and return.
So with your complete hydraulic pump deletion, did you keep the aux pump and lines?
Also, you mentioned the alternator (original one) only pulling 110 amps, do you have a suggestion on an alternator that would work better? Cause I’m installing an Derale 16833 dual
