New 2000 LS owner requesting general information
daabob77
Seattle
Hello all,
I just purchased a 2000 Lincoln LS with the v8 engine, 60k.
I am not familiar with this car, and want to know what some likely failure points are, (I've heard the transmission can be a weak point,)
so I can go ahead and knock out as much maintenance and make this thing last as long as possible
Any information would be greatly appreciated. Thanks in advance, Christian
The number one problem are the plastic cooling parts. They fail from heat and time. They will be full of micro-cracks that you can't see.
Since Ford has abandoned the LS many years ago they have also obsoleted all the cooling parts!
Spend some time searching this forum for details. Look for the forum member JoeGR. He has stopped posting now but he was a stone cold expert on these cooling problems and had a number of LS's.
Ignore whoever told the transmission was the problem. It's a dead common Ford 5 speed and it was used in millions of everyday Fords like the Explorer as well as the LS. So parts are everywhere and shops have been rebuilding these for many years. If you have transmission problems it's just a matter of money to repair it.
Be aware that the lack of cooling parts is the real issue and I don't know how your going to get around that.
I still miss my 2003 V8 Sport LS but with what Ford did I had to move on and now I have had several Jaguar's.
Hello all,
If you are looking for a hobby, you found one.
If not, get rid of it quickly!!!!
The transmission is ok as long as the fluid has been replaced. In 2000 it was not synthetic. After 2003 I think mercon 5 became synthetic. Check the condition of the fluid and a fluid change is probably recommended. When I get a new vehicle (used) I change all the fluids out. Do not forget about the fan fluid. At the least suck the fluid out and replace it.
That is some extremely Low Miles. I will share what I learned with my 2001. Prior to May-ish 2001 the engine had some major flaws in the timing chain and associated parts. After then they upgraded and corrected the weak parts. You might still have the problematic ones, see if the car has a record of that repair. The transmission issue was a shift kit issue, not that bad about 150 bucks parts plus labor if it starts to not shift right. It doesn't require the transmission be dropped, just the bottom pan removed. Read through this forum for all the overheating issues from the plastic parts.... see what you can still nab for Jaguar S-type replacement metal pieces. URO is what I got.
