2002 Lincoln ls 3.0l timing parts
1Ratchet2
Wisconsin
First Forum I've ever joined. Glad to be here and looking forward to gaining some insight and possibly being able to help share any information that can help others!
I have a 2002 Lincoln LS 3.0. I recently acquired my Lincoln and it came with a timing chain knock by valve cover. I tore everything down to replace the chain, guides, tensioner and all parts that made sense along the way as it's a bit labor-intensive. Any input is welcome but my main question is if anybody knows where to get new guides for the timing chains?
I ordered, what sounds like, the last 2 out of 4 that are at a dealership across the whole country. The two I ordered are the ones that the tensioners go behind. I cannot find the two chain guides that are the more "straight" ones. I tried looking for replacement nylon or plastic runners for the metal base, if you will, for the guides and cannot find that either. Really don't want to put the old part back in because it's slightly pitted and feel that would be a poor decision to have all the new parts and labor just to seal it back up with two guides that may fail and be the weak link... no pun intended. Any input or help with this would be greatly appreciated! Thank you very much!
Thank you, I appreciate the help! I've tried a few with no luck because they said the part number would remain the same whether at the Ford dealership or Jaguar. The parts come up as discontinued and I can't find an after-market. My Lincoln Ford dealership did a search and found, what they told me, to be the last 3 timing chains available in the country so I'm good there. If they are right that leaves one chain for somebody to time half an engine...ha.
Just received 1 timing chain tensioner guide from one dealership and the other one is in the mail. Just have the two "Straits" to go. I did find out quickly that just because one dealership tells you you are out of luck don't give up. The next one might go the extra mile and figure something out. Thanks again!
Try Rockauto?
Thank you for the help! I tried them and ordered a couple of the parts that you have pictured there. They were not the correct ones. Some of the parts I've seen look close and I've ordered them just to find out that they are about an inch too long. Example would be the second one down on the list in your picture. I ordered it and cut my fingers crossed but no luck, had to return it. The part number isn't exact and was hoping that was an after-market thing but the part would be right. The whole number is correct for the right side guide besides the F8R in the beginning. Lincoln Ford has the part number as 1W4Z6K297CA for the right side and left side is the same besides the last two letters are BA. PartsGeek had a 2000 to 2008 Jaguar S-Type timing kit that had the correct guides that I already have that go against the tensioners but the kit stops there and there's no other guides. I also ordered replacement nylon to put on the guide and it comes too long so that results in the last connecting tab not lining up. Thank you again!
That does seem to look like one of them... I'm not positive. I'm hopeful because sounds like you are sure of it and I'm not too well-versed on this. I have 2 guides that I need yet one possibly being this one and the other "straight" guide. I want to attach a picture but it says file too large so I'll see what I can get to load, if any. Repeating but I have the two curved ones that go against the tensioners already. Looking for a part number and something to go off of to call Jaguar if that's what I need to do. Thank you again
1999-2002 JV6 “AJ60” (your engine) vs 2003 and later JV6 “AJ62” with vcti units
rockauto list the wrong parts because they think your engine is a duratec 30 out of a taurus/escape/etc.
You are absolutely correct! Thank you so very much for helping me out with the second to last part I need! The picture you have with the whole kit... The guide in the upper left darn near looks like I could possibly take and cut that extra bit off, unless it separates somehow and I can't see it in the picture, and that would come close to matching for the other side. Or am I looking at that completely wrong? Also, you're saying that the part that you showed me at RockAuto would be the correct one just so I got that right?
all the parts off rockauto are wrong because it thinks you have a duratec (taurus and escape) engine instead of the jaguar v6.
you can buy the guides attached to the 03+ vcti solenoid housing for a little over 2 bucks, they just clip in. it may fit with some modification. part C2C8279
You think those would work for the left on the right? I'm willing to give it a try. Thank you for all your time and help!
Tried ordering (nylon/plastic runner piece) from Jaguar and received an email today saying the order was canceled due to discontinued part.
Wasn't looking to have all new parts besides two pieces of important plastic but just may because I'm not having much luck...
Hello,
i have the same issue. My car its a Jaguar s type 3.0 v6 model 2001 and i cannot find the discontinued part( XR85175). I have 3 new timing chain guides, 2 new chains , 2 tensioners , 1 timing sporcket. The condition of the old timing chain its good enough i think. Should i use it again? Any tip please?!
Man.. I am laaate. But anyway -- big thing with timing guides is whether they're brittle. That's something that happens when a vehicle sits a long time and/or when it overheats, sadly. I prolly aught to check on mine.
I'm sure you've moved beyond this, but if you've been looking for OEM parts, I'd say don't sweat it so much. Companies that I see produce garbage parts are... Standard motors, Dorman, whatever O'Reilly's re-manufacturer is called. Moog is pretty junky (them and their grease-able bushings that blow out immediately despite advertising that they can release excess grease). If it's aftermarket non-performance exhaust, anyone other than Walker will sell you parts that don't fit
I wouldn't re-use timing guides in lieu of using non-oem.
Hi,
i already used the same guide, i couldn't find any solution. The only way was to order the whole timing chain kit through Jaguar. The car its not ready yet so i cannot give you more info.
Hey, it's alright -- if you felt like it wasn't falling apart in your hand it's not that bad. I've had the plastic on them quite literally crumble in my hands like tortilla chips. Wasn't even trying.
Next time around though, I'd suggest trying aftermarket parts like the following
2001 JAGUAR S-TYPE 3.0L V6 | Shop Now at RockAuto
If you're concerned about brand quality, apparently that INA set is part of a group with FAG and Luk. Both awesome companies.
all the parts off rockauto are wrong because it thinks you have a duratec ( taurus and escape) engine instead of the jaguar v6
Oh jeez, really? That's absolutely awful -- I'm so sorry to hear that
Yep! I can see the difference between 'em now
Here's google's list:
Faulty VCT Solenoid: The Variable Cam Timing (VCT) solenoid is stuck or failing, a common issue.
Camshaft Position Sensor Issue: Sensor wiring damage or a failing sensor.
Cam Phaser Failure: Damaged or damaged cam phasers causing incorrect timing.
Timing Chain/Position Issue: Timing is physically out of position.
Oil Control Issues: Thick oil or a faulty oil control valve, especially with modified oil pump
When did this show up in relation to your servicing of the timing chain?.. Has the car ran since, and ran well?
I'd love a link to a youtube vid of your idle, and perhaps some revs.
I could also see VTC issues being a thing if oil has been overfilled. Mine were siliconed in by the previous owner but they work still!..
