Mattmatt
Have a 2004 Lincoln LS 6 cylinder my Oil light stays on even though my dipstick says I have maximum oil. Could the light be coming on because I have too much oil?
The oil light has nothing to do with oil quantity, that's what the dipstick is for. The oil light is indicating low to no oil pressure. It could be minor (bad oil pressure switch or wiring), or it could be major (oil pressure really is low). If you have driven with the light on for a while, then you either new a new switch or a new engine. (Keeping the engine running with low/no oil pressure is a major mistake.)Have a 2004 Lincoln LS 6 cylinder my Oil light stays on even though my dipstick says I have maximum oil. Could the light be coming on because I have too much oil?
The light goes off when I start to go or when I push on the accelerator pedalThe oil light has nothing to do with oil quantity, that's what the dipstick is for. The oil light is indicating low to no oil pressure. It could be minor (bad oil pressure switch or wiring), or it could be major (oil pressure really is low). If you have driven with the light on for a while, then you either new a new switch or a new engine. (Keeping the engine running with low/no oil pressure is a major mistake.)
The fact that it goes away when you accelerate is natural, considering that oil flow increases with RPM to keep the engine lubricated. But, that means that it might not be getting enough oil pressure at idle, which could be your oil pump starting to go bye bye bye. Or you could get lucky and away with faulty pressure sensor/wiring.The light goes off when I start to go or when I push on the accelerator pedal
www.lincolnvscadillac.com
Surely the oil filter would've caught it....unless it was a Fram branded oneI just change filter and oil when I did my chains and I got the very same issue . Really hate to think of it but when I was takin g the front cover off I thing a little grim made it's way in to the pan ....I hope it didn't get sucked up in the pump and that be my issue.
Well, the pump is before the oil filter, not after. That said, the pump should be tough enough to handle a little grime.Surely the oil filter would've caught it....unless it was a Fram branded one
