smegun
overheating issue ....i was there but i didnt change the hose and fitting under the manifold and heat pad was in pieces i havnt been able to sucessfully purge the system again after checking the the main timing set ....(Pain pain) the oil cooler was ok i did a full coolant flush before i tried to get it running but there is a problem with high temps like i think i got air coming in displacing the fluid im not loosing fluidat least the tank stays the same some drips around the front of the cats is present .... only time i had it working and cool is when i completely bypassed the heater core im worried that what ever i saw there gromet and or plastic or hose is bad under there
