As part of the V6 spark plug/cop access, you have to pull the intake manifold upper plenum, which is highly disruptive to the top end of the engine with the amount of hoses and cables to disconnect. There is a PCV line that runs from the back end of the engine, driver's side, across the upper plenum, and it connects to the throttle body. The hose is about 5/16" or 8mm and stiff plastic, but the ends are rubber boots that accept the 5/16" hose on one end of the boot and and convert it to 5/8" to make the connections to the PCV system under the intake and the throttle body. On my V6, that hose adapter at the back end of the engine was significantly cracked and caused a very rough idle once the engine got to closed loop operation. It would sit there and shake like a top fuel dragster engine at idle, making the ugliest popping noises and nearly stalling. Ran like a champ for driving and power, but could not idle down while coasting until the car reached a full stop. (std trans)  Well after I found this problem, the car now behaves properly at idle and running/coasting. I would imagine that many of the V6s have this problem.
