Quik LS
The motor is fine.... it's the weight....
Who 'presumes intact'? Is there a formal definition? I've never seen one!
Please read what I wrote. The piston is a flat top and no 3.9 piston I ever saw even has valve reliefs. The combustion chamber is a classic four valve pent roof. The valve would have to protrude beyond the chamber in order to hit a piston, and factory lift figures make that unlikely.
In order for contact to happen, the most likely scenario would include broken valve-train pieces and not just a timing miss-event.
It IS fairly common to pull the valve-stem/keeper interface through the factory retainer, and 'drop a valve'. This inevitably causes a crash.
KS
here are a couple of pics of some LS heads I have....
Sorry took them with my phone..
looks like the valves extend past the edge of the heads by about 7mm.
I do not have pics of the piston in the cylinder at TDC - so I do not know how high it come to the top edge - but 7mm seems like a lot.
Sorry, I didn't realize that you had changed the subject. I thought you were talking about the AJ being an interference engine, not whether or not a piece of debris in the cylinder could cause problems...Please read what I wrote.
The problem i'm having is that the transmission shop said if they take mine apart and the valve body is damaged then i have to pay a fee for that along with the cost of finding a new transmission. I'm just worried about it cause my trans went out with no warning at 87k miles and the fluid was burnt although i had just had a synthetic flush at 75k miles. I've been looking for a used transmission but most of them have more miles then my own had. At the cost of buying a transmission i could get almost a whole car and part it out. I know there is enough demand for these to make it worth my time.
If anyone is selling a transmission that works please let me know. I'm ballin on a budget. The idea of spending 1800 on a trans scares me to death just to think that it may happen 6 months from nowI'm a single dad and stuck driving a pickup truck all the time now.
Where did you get it flushed? When ever I get a faulty transmission, the fluid is the first place I look. If there were no signs before (hard shifting, rattling at distinct speeds burnt smell) then that means, your transmission went out just over 10,000 miles after their service. Did they use Mercon V and check the fluid level properly. Before you take anything apart, you should begain an inquarry in this direction. Are you in Cali?
I know I’m reviving an old threadhere are a couple of pics of some LS heads I have....
That's actually kind of a bad question.But maybe someone who know can confirm if the pistons come up within 7mm of the deck of the block?
Luckily I have not had an issue with overheating and I do not suspect bent valves or timing jump; I merely ask because I own a high mileage 3.9 L that has a brand new transmission. I’m trying to suss out the weak points of the vehicle; really I’m trying to figure out whether the timing chain should be changed arbitrarily based on time and mileage or if it can safely be run until it has an issue with itThat's actually kind of a bad question.
If the valves do extend into the combustion chamber 7mm, (as Cam's 3rd pic in post #30 shows)...
...and the piston at TDC is 7mm from the top of the block deck... then, (allowing for the head gasket thickness), the valve is almost hitting the piston on a cold engine.
Start the engine up... and as everything "grows" due to thermal expansion... then the valve and piston would come in contact with each other.
There are formulas to calculate all of this, (figuring in the stroke and deck height measured from the center of rotation of the crankshaft), but I don't have that info handy... and honestly don't feel like doing the math.
The important question from me... would be why do you want to know the answer to your question?
Did you have a timing chain fail? Do you have low compression on one or more cylinders? Do you think you have a bent valve?
More info is needed.
www.lincolnvscadillac.com
