Are there any recommended options for an android auto head unit for a 2004 LS Ultimate with the premium audio package/nav/touchscreen? Need new speakers and don't want to go through the nonsense of trying to find all the OEM crap.
					www.lincolnvscadillac.com
				Holy yikes that is an expensive head unit! Would that Maestro ADS-MSW work with another, cheaper, android auto head unit?I went with Kenwood Excelon DDX9905S Multimedia Receiver combined with a
Maestro ADS-MSW Universal Analog Steering Wheel Interface. Love the combo in my 2006 LS Elite formerly with the OEM Nav/Touchscreen
Switching out the THX nav does complicate things quite a bit.
THX navigation to aftermarket
I've been having some problems with the tuner in my THX nav headunit. After being unable to repair it, I decided to go after market (JVC KW-NT700). Fortunately, I was able to retain the factory amps and speakers. I used the following diagrams to figure it out. Unfortunately, there are no...www.lincolnvscadillac.com
The speakers in the rear deck are the subs only. I'm sure that the foam on those has rotted off, and they need to be replaced. If you bypass the 4-channel amp, you will have to run wires from each door back to the head-unit under the dash. To me, that is a lot more effort than re-using the amps.Thanks Joegr!
So you wanted to replace factory head unit/nav and leave the factory THX speakers, is that correct?
My rear deck speakers are bad and I don't think they sounded all that great in the first place when they still worked.
Would would these issues you encountered still be present if I wanted to rip out the existing speakers and replace with aftermarket speakers that were compatible with my head unit/amp combo? Wouldn't this avoid the whole wiring harness modification issue?
I 2nd Crutchfield. Top notch company.Ive found Crutchfield to be a good place to find units that will fit our car (you can sort by LS) and its generally pretty accurate which for the LS is no easy feat. Crutchfield is not always the cheapest but their service and tech advice is typically very good.
