SultanGris
Got both these codes, they come and go sometimes only one sometimes only the other sometimes both. Runs good initially but after driving a while and it warms up it sometimes loses power / acceleration but if I shut it off and turn it back on then it goes again for a while.
P0190 says fuel pressure sensor rail circuit, p0191 says the same thing but Auto zone said it was the pump. A new\used pump was installed on the passenger side before I bought the car. I've heard it's a saddle tank and there's a jet pump and a regular pump so I was just wondering which one is on what side and what side is the float for fuel gauge on?
Found a thread that had a similar issue and code but it was never resolved so I just wondered if anybody else ever had this problem and what it turned out to be.
I noticed my vacuum is about 17 to 19 when I'm idling or driving but when I accelerate it goes down quite a bit saw some 8,6, and even saw 1 point something on hard acceleration, is that normal? What should the vacuum reading be, using torque lite to monitor, bought wrong Bluetooth adapter for forscan, what's the best Bluetooth adapter for Android forscan? Thanks.
