Ant3.9LS03
Looking for some suggestions. Cooling system is brand new on my 03 3.9 Gen 2, both radiator hoses, radiator, thermostat, housing assembly, all gaskets, 94n99, hose under intake manifold, water pump, degas with new hoses, aux pump, dccv and both hoses from dccv to upper hose and aux to thermostat.... I'm still running way hotter than the car should, my Temps stay around 212 214 then eventually rise to 223 225, I've used airlift kit on my car to 25 psi no air leaks, refilled completely airless, tried to bleed after with no air, and car is still running these temps, at this point idk what to do, what is my problem here? My fan kicks on fine from what I can tell. Turning the heater on makes temps fly down. Anyone with any advice to point me in the right direction would be the best help at this point, I'm left with changing my CHT sensor? Or am I stuck with a faulty thermostat? Bad fan? Another sensor I'm not aware of? Thanks guys... This is beyond frustrating as I just want to drive this damn car already... At this point I have money for the man who saves me from this nightmare if possible! And noting I'm ready to buy a cht sensor and new thermostat if this is poissbly my problem...
