2004 3.0 AJ-V6 Lots of Oil in Plugwells(Spark Plug Tubes)
INFOOL7
Batavia
Checked the compression in the cylinders and they're all good
Changed all of the valve cover gaskets
Still have oil in the plugwells.
EGR valve? Could it be coming from the bottom of the tubes?
...EGR valve? Could it be coming from the bottom of the tubes?
EGR, no, not even remotely...
Bottom of the tubes, yes. There are o-ring like seals there. They are to be replaced along with the outer valve cover gaskets. Where else could the oil come from?
Wow. Thanks for the quick response.
oops I was thinking PCV.
Does anyone have the torque specs and tightening sequence for the valve covers I am about to redo them this weekend.
