So I've been having shifting issues as well. I want to get it resolved. I have hard forward/reverse engagement. No slamming between gears but sometimes I will get a little kick. Mostly it feels like someone driving a manual with no experience. I'm thinking of sending the PCM for diagnostics and repair. Before I do though I want to go over some things to rule out other possible causes. The original owner gave me his reciepts and one of them was for the transmission shifting issue. It looks like they changed the solenoid pack in their repair. I did remove the solenoid assembly, pull the bushings out and clean the holes and test the resistance to the solenoids. It didn't fix the issue. I have had a couple of days where the temp here was over 95 that the car shifted almost perfectly but not every time it was that hot.
The car runs a little rough on a cold start and them smooths out after warming up. I ran forscan and these are the results.
DTC ===
Successful DTC reading, no error codes found
Module: Powertrain Control Module
===END PCM===
===OBDII DTC ===
Module: On Board Diagnostic II
===END OBDII===
===DSM DTC ===
Module: Driver's Seat Module
===END DSM===
===DDM DTC ===
Module: Drivers Door Module
===END DDM===
===EATC DTC B1242===
Code: B1242 - Air Flow Recirculation Door driver circuit failure
Module: Electronic Automatic Temperature Control
Diagnostic Trouble Code details
--- Possible Causes --------
This DTC is generated in Continuous mode. Remote Climate Control Module generates this DTC when the recirculation door driver 1 or driver 2 is shorted to ground. This DTC is also generated when driver 1 is shorted to driver 2.
-Suspect Recirculation Door Remote Climate Control Module
===END EATC===
===EATC DTC B1265===
Code: B1265 - Cold Air Bypass Divert Door driver circuit failure
===END EATC===
===MC DTC U1262===
Code: U1262 - SCP Data Link Fault
Module: Message Center
SCP Data Link Fault
Operator Action
Run self test.
All CMDTCs
Fix all relevant DTCs then clear codes and retest.
Note:
DTCs that start with 'U' are faults which occur during module-to-module communication.
Modules should never be replaced based only on a 'U' code. These codes do not always indicate a problem, and can be caused by normal diagnostic functions, carried out on the vehicle.
===END MC===
===MC DTC P0404===
Code: P0404 - EGR valve position control performance or range fault
===END MC===
===IC DTC U1041===
Code: U1041 - Vehicle Speed Data Invalid
Module: Instrument Cluster
SCP invalid or missing data for function read vehicle speed
===END IC===
===IC DTC B1875===
Code: B1875 - Turn Signal/Hazard Switch Signal circuit failure
On-Demand DTC Entry Criteria; Right Turn Signal Switch, Left Turn Signal Switch, & Hazard Switch inactive
- Switch circuit in OFF position.
Circuit Failure; Switch circuit not OPEN.
Continuous DTC Entry Criteria; Right Turn Signal Switch, Left Turn Signal Switch, & Hazard Switch circuits are activated.
Circuit Failure; Right Turn Signal Switch, Left Turn Signal Switch, & Hazard Switch OUT-OF-RANGE.
-Suspect Turn Signal Switch Hazard Switch Steering Column/IP/Lighting Module
===END IC===
===IC DTC U1262===
SCP Data Link Fault
Operator Action
Run self test.
All CMDTCs
Note:
===END IC===
===GEM DTC B1794===
Code: B1794 - Open Power Circuit or Shorted Power Circuit
Module: Generic Electronic Module
===END GEM===
===GEM DTC B2312===
Code: B2312 - Passenger Mirror Horizontal Position Sensor circuit failure
===END GEM===
===REM DTC B1201===
Code: B1201 - Fuel sender circuit failure
Module: Rear Electronic Module
This DTC can be generated by:
-Open Fuel Sender circuit.
-Battery short Fuel Sender circuit.
-Suspect Fuel Sender.
-Suspect Virtual Image Cluster.
===END REM===
===ABS DTC ===
Module: Antilock braking system
===END ABS===
===RCM DTC ===
Module: Restraint Control Module
===END RCM===
I have the 0404 code for a while now on and off in forscan ( mostly on) and I have tried removing and cleaning the egr valve before. I also looked at the fuel trims but forscan has so many that I'm not sure which ones to look at. Also some of the trims say obd so should I be in a closed loop for them? Any help would be appreciated. Please give practical advice and not throw part at it.
