Robert Crain
Greetings, when replacing the front upper control arms, is there enough clearance to remove the two body bolts or does the strut assembly have to first be removed? Are these two bolts camber bolts that affect alignment? Should these bolts be replaced or can they be reused? Thanks! Rob
