erictw
I am starting to accumulate these and am wondering if there is a way to check them with a meter. There are three pins on the connector, I am guessing one for each solenoid and a common ground, but they don't seem to be marked in any way, and I have no idea what the proper resistance would be, but I have already changed this once with no improvement and still get ground fault in the code, I'd like to be sure of the part before I change it again.
I have also determined that the easiest way to disconnect the lower hose from the degas bottle is to remove the engine and/or brake booster first. Just a tip.
