So I'm getting intermittent codes. It seems to alternate between P0320 and P0340 but it hasn't tripped both at the same time. I'm getting several symptoms and I haven't been able to figure out the cause yet. The car is running pretty awful starting from idle. It's idling high when I first start it and once it gets down to normal idle of about 750 it will just randomly die like I just turned the key off. Sometimes when I'm just sitting with the car in park and I rev it up, the RPMs are really slow to come back down to normal idle speeds. Ok. Then when I'm driving it, sometimes it will die sitting at a stop light or die when I accelerate from a stop, or accelerate in general. Typically, when I get up to speed, it will run alright. But when it's sputters at acceleration, the tach will either jump up to 7,000 and down to 0 or jump all around in between but just run awful. When it does this, the battery light typically turns on. Other symptoms. The transmission will shift hard sometimes or not want to go into drive. The ABS light came on and once the ABS was kicking on while driving on dry roads. When it first started and I was running on the highway, I was running with cruise control and after I braked, it shut the cruise control all the way off where pushing resume wouldn't resume, I had to turn the CC back on. Sometimes after I start it, it will miss on a cylinder real bad and if I shut it off and back on, it will stop missing. It never gave me a misfire code though. Yep, that's what's going on and I don't know why! I've replaced the cam position sensor, crank position sensor, fuel filter, and fuel pump over the last 3 weeks or so and it just keeps getting worse. Any help in diagnosing would be a life saver! Thanks!
The car is a 2002 Lincoln ls v8
