Benjaminws
so my gf started the LS yesterday and it rev'd up to 4000-5000 rpms, came down, and the engine started shaking, code pulled was for O2 sensors, would bad sensors make these things happen?? Thank you are the help!!
V8So, there actually is no code that says point blank that an O2 sensor is bad. Why don't you post the actual code(s) that you got?
O2 sensor failures do happen, but most of the time they are falsely blamed for reporting a problem somewhere else. Don't shoot the messenger...
Also, need to know if this is a 1st or 2nd gen, V6 or V8.
And how do you recalibrate Adv trac
How expensive is it to replace cat
Do I need the whole set or can I just get the right side?
