need code advice
jerrym3
Bergen County
My LS "check engine" light came on. Brought it to a local mechanic. The codes were:
P2072 "Throttle actuator"?
PO171 "control system ice blockage"? "bank 1 and 2 lean"?
PO174
He cleaned up some of the system parts hoping it would eliminate the "lean running" condition. It didn't.
Test drive, light was out while the car was cold, but went on when the engine warmed up.
Any advice appreciated.
Well, unfortunately a lot of things can cause the lean codes. I would guess that air leaks or a dirty MAF would be among the more likely.
On the throttle code, the first thing to do is to try and determine if it was really stuck, or if it was EMI from a marginal COP. Force the throttle valve open by hand. Does it move smoothly, or are there any catch points?
Was the throttle body one of the parts that was cleaned?
Update
Went back to the mechanic. He checked for vacuum leaks and cleaned the MAF connections. Same story.
First drive, light is out. Second drive, light is out but then comes on once the car warms. Then, light stays on for all drives.
Otherwise, car is running perfect. No misses, starts up 1-2-3.
Bite the bullet and change the MAF?
Thanks
Update
Thanks
    Delphi SS10387 Throttle Position Sensor
    by Delphi
    $10.11(1 used offer)
    6
    Amazon open box deals has this maybe give this a try see what happens to the check engine light
Update
Thanks
Personally, I wouldn't chance cheap coils.
It's not going to be that on his gen II. It would be a different set of codes and problems.
I picked up a MotorCraft sensor at a discounted price. Installing it this afternoon. (My independent mechanic recommended going with MCraft).
Fingers crossed.
