We drove just a few miles yesterday (5 miles maybe), stopped to eat and when we came out about 1 hour later, I noticed a leak under the front drivers/middle side of the car. I could see some slight dripping from now what I recall as around the middle/front (?) of the engine underneath. I took a white napkin to it and could tell it was antifreeze. Backed the car up a bit and took this photo. It was about 113 degrees in the shade when I took the photo. Looked under the hood, couldn't see where it may be coming from. Took a chance and drove it home 8 miles. It didn't leak on the way nor once we got home and nothing over night. Temp gauge stayed normal and no codes or anything came up, car ran fine.
There is antifreeze in the reservoir bottle, but only about an inch or so up from the bottom. I noticed the antifreeze is light pink in color, not the gold/yellow that should have came in it. I'm assuming the older couple who owned it since new maybe had someone do a flush and they put in the wrong antifreeze. The car only had 48k on it when we got it last fall. I understand that color doesn't always tell you exactly what type of antifreeze it may actually be. But I'm assuming what's in there may not be correct.
So, anyone have any ideas as to what may be happening? I know all about the plastic parts problem, but so far at least there isn't any signs of anything other than the coolant loss after the short trip and nothing lost or wrong on the trip home. Is it possible it was just so hot out that it caused a quick over heat or something? Where should coolant be coming from exactly when over heating?
Another question, is there another antifreeze that I could buy in place of Motorcraft Gold since my closest auto store doesn't stock it and I'm assuming I'll be flushing out the system one way or another soon anyway. Zerex G-05 is the same, correct? Anyone know what color G-05 is? Thanks in advance for the help everyone!
