06' THX Nav, AUX or Aftermarket?
xjoncostello
Norwalk
So I'm looking to get an Aux input on my 06 LS with the THX Nav
I can't find any PIE Aux/s
So will this work?
https://www.walmart.com/ip/Pac-Aai-...62769&wl11=online&wl12=41246303&wl13=&veh=sem
Or is there now a Aftermarket wiring harness I can just use to install a crappy radio that has an Aux port.
Don't really care about the radio just want to mount my Dell Venue 8 7000 but need AUX.
BTW new to this forum and a new LS owner.
Does this matter I have only
Sound
AM
FM1
FM2
CD
I don't have sat, like I've seen in other posts.
If you connected a compatible satellite receiver or aux input, then the FM2 button would change to say "SAT" ("FM1" would then toggle between FM1 and FM2.)
Oh I see, I guess I'll give it a shot with that Aux thing, hopefully it works, if not I'll follow you're write up. Will your write up also work for just a standard radio like a little pioneer guy, not a double din? Like I said just need something cheap just to use the aux port to mount my tablet.
Yes, but you'll need a single din dash adapter instead of the double din I called out.
Good find joe. That one is specific to the THX, and would feed through the amps for full sound, not fm broadcast.
Thanks! Will give one of those a try for sure. Just going to have to sell something to spare the extra cash.
How much does a 06 Passenger Headlight go for? i believe its the xenon ( has that hid box built in )
i have the driver one as well but the front glass is broken.
...How much does a 06 Passenger Headlight go for? i believe its the xenon ( has that hid box built in )
Looks like about $100 to $250, depending on condition.
