MysticMac
After having a tiny rain storm here in Vancouver I noticed condensation in my trunk and actual water on the right side under the tail light housing and under the module in the trunk near the gas tank lid. The module it self was pretty dry but still not good to be near water of course. I cleaned it all out and dryed it. I figured it was wet and damp in there because I had removed a drain plug and lost it. So there has basically been a hole in the bottom of the spare tire well, I know thats not where the water was coming from. I found a reply on a random forum about a guy having the same exact issue. Turns out it was his seal around the tail light housing it self. Is there a part number for this? Or can I just use silicone? I will be removing the wire harness cover and inspecting all wires and junction boxes/fuse box for corrosion before starting up again. Also,could it be leaking from the top of my trunk? is there a seal there? I do not have a moon roof.
If anyone has some insite on it let me know.
Thanks
Thanks
