There are quite a few threads on what to do, or what you need, but none of them i've saw go into detail with pictures about the parts.
I picked up my 03 LS for $400. Got it running (clogged cats), It overheated first time I drove it, checked the coolant level and it was almost a gallon low. Posted about it here, Joegr immediately linked me to a thread and told me I basically need to replace everything in my cooling system. Im hard-headed, and stubborn and thought "no way, my stuff looks fine." I knew he was right, but I hoped maybe by sheer luck, I could drive the car for quite some time before having any of the cooling parts issues.
My plastic pieces looked nice and dark black, hoses looked fine, I couldn't see any of the dried white residue (Which is dried up coolant), I just wanted to replace whatever had leaked, and be on my way to driving this car finally. He also mentioned a common broken area in the radiators that leak. (He had been right about everything else on my car, and was right about this as well) I replaced the radiator, and all was well. System was building and holding pressure like normal, no air getting in, etc. I had a fully normal functioning cooling system, and no overheating under any circumstances.
Fast forward to last week. I finally started driving the LS to work (35~ highway miles each way). All was well, fast forward to the 3rd day, appx 200 miles were put on the LS since I started driving it. (It has 186,000 miles) I smell coolant very strong while cruising on the highway. Temp gauge starts to rise, so I pull over, pop the hood, coolant is EVERYWHERE under the hood.
Used my newly-bought AAA membership to get a free tow home. Took the intake tube off, couldn't see ANY signs of a broken hose, or failed plastic part. I knew there was way too much coolant spilled on the engine to be a plastic part spewing out of a crack or something.
My thermostat housing blew an end cap off.
I thought my stuff looked newer, like it had been replaced within a reasonable time. My degas bottle was yellowing, but didn't look that yellow.
Here are some pictures, now that I have the system "broken down" which wasn't hard at all. I took my time and had all the parts i'm replacing off within maybe 2 hours. Hardest part ive experienced so far was the hose clamp on the degas bottle bottom line. I ended up pulling it far enough to get a wrench on the clamp and wiggle it out of the way.
Here was my engine when I was on the side of the highway at 4am. Doesn't look like much, but the drivers side of the engine was drenched in coolant. Fan, radiator, hoses, top of the engine, etc.
Pass side was pretty dry
Then I finally saw THIS
This is on the drivers side. This hole normally has a cap of some sort glued in place. (Not a cap that you remove, like a radiator cap)
See, I still contemplated on ordering just the thermostat housing (3 pieces) because thats all that was broke. But in the back of my head, I could see Joegr shaking his head, and saying "I told you so" if I skimped out and just replaced what was bad.
Now with the wiper cowl, and strut brace removed, it was much more evident that my degas bottle was baaaaad.
Ive always read that the degas bottle develops cracks in the back, that you wont see unless you remove it. Nah, not mine. Its not leaking.
Wrong.
Front
Check out that color difference...
Said cracks
Here are the common failure points. Any plastic you see in this pic will need to be replaced sooner or later.
Lower rad hose (If you have the oil cooler, it has the two smaller hoses coming off)
Upper
This is 2/3 of the thermostat housing. The third piece is still on my motor, because I have to buy some new cut off wheels to get the bolt out of it. I went the route of not removing my whole intake, though it doesn't look like it would be much extra effort, and wouldn't hurt to clean it and put new gaskets on. I may end up still doing that.
The part thats supposed to have a cap
The other side that has the cap
See what I said, the outside doesn't look so bad. Nice and black, fairly clean. Check out the inside
Check out those fat hoses...definitely not supposed to be that bloated looking
Now heres the inlets on the heads. Again, with everything in place, I saw no signs of leaking. Very apparent leaks now that the parts are removed.
And again, check out the inside of that plastic piece
Also a good time to change the gasket on my intake, because it definitely didn't have a good seal
Unfortunately they don't make any aluminum replacements for Gen II's like the Gen I.
Helpful threads: (Be aware, some of these are years old. Prices of parts has definitely went up on some)
http://www.lincolnvscadillac.com/forum/showthread.php?91092-GenII-LS8-Cooling-System-Overhaul
http://www.lincolnvscadillac.com/forum/showthread.php?78659-Coolant-plumbing-replacement
http://www.lincolnvscadillac.com/forum/showthread.php?77940-Coolant-Hoses-Total-Cost
Here is a photo album on Facebook full of pics of the job
https://www.facebook.com/TooManyToys-104882132926478/photos/?tab=album&album_id=183765648371459
If you remove the intake, you'll need a set of fuel line disconnects like these:
https://www.amazon.com/OTC-7337-Fue...fuel line disconnect tool&tag=viglink20729-20
Wrong.
Front
Said cracks
Upper
