2000 LS Lug Nuts - has anyone sourced them? Never thought I'd ask about lug nuts!
TomPJr
Shingle Springs
Hey Team,
Seems the little decorative acorn covers on my lug nuts are mangled - no doubt from someone thrashing on them at a tire shop....
Went to get new tires today and they had a pretty good challenge in getting the lug nuts off.
Has anyone else out there experienced this and sourced some good replacement lug nuts?
Tom
after having my third chrome cap start spinning, I abandoned the Lincoln nut, originally going with a gorilla lug nut but then changing to the sebring lug nut for a better fit.
Yes the chrome cover on them is very poorly designed and the lug nuts get mangled if not removed carefully. Over the years I have bought lug nuts at O'Reilly. Dorman lug nuts if I remember correctly. The design is better. The Chrysler Sebring lug nuts are actually preferred. Not a chrome cover on it like the Lincoln ones and they hold up over time. The lug wrench size is different, maybe 18 mm vs 19mm so you might need a different lug wrench in the car. Don't remember for certain.
All of mine are rusted and the chrome is flaking, but it beats a pretty stamped metal cover that detaches.
Sebrings are 21mm. Stock is 19mm. It turns into 18mm if you peel the metal cover off because the damn thing is spinning... I bought an 18" Craftsman Industrial 1/2" breaker bar and single Tekton deep socket for $30. I like the breaker bar setup so much more than the stock wrench I went and replaced it in my other car, too.
Dorman 611-229. Rock auto has them $1.46 if you buy 10+. They are chrome, not sure if yours are but I replaced mine with them works great.
This team is awesome - thank you! I will log onto Rock Auto and buy the Dorman 611-229 units. Never in my life would i have anticipated lug nuts to fail under somewhat "normal" use. THanks everyone! Tom
Same here. They seemed to rust pretty quick, less than a year (6 months?) of installing them.
Definitely don't try to buy them individually in one night from 5 stores at $4 each... definitely not the way to go :(
I bought a set of conical Gorilla spline tuner lugs online, only to very quickly learn about how A) stock LS wheels really want "mag" lugs and B) the thin "tuner" lugs go right through most of the holes in the wheel. So as to not delay the car any longer because I was impatient, I rushed out and paid $80 for 20 crappy-but-effective nuts
