Door trim panel R&R
dosMarkos8to's
Central Texas
I need to replace the outside passenger side mirror on my '98 Mark. Have tried wording search to turn up help on how to r&r the door trim panel with no luck....so I am frustrated and have run out of word combinations..need help! Can anybody guide me to any posts, with pics would be great, on how to get the panel off?
Thanks,
Dos
The panel slides upwards, take the door handle trim off first then slide panel upwards from the edge towards the hinge. Be careful of the window switch wires...... I have to work on mine in the morning ill post pics
First pull off the door handle trim
Then the window switch panel. Pry from the left side. Then Unscrew and pry off switches.
Next, window switch. Again pry from left and unscrew and pry off
Next the light on the bottom left will need to be popped off and unscrewed.
After those are done just push up from bottom of panel to unseat the window molding. Be carefull of the mirror panel it will hang you up.
Then just finish un doing harnesses and you good to go.
Passenger side much simpler due to lack of switches.
Good luck
