Driving my 06 LS, check engine CEL came on. Took to Auto Zone, Scanned codes p2196 p2198. These 2 codes are 2 different, Bank 1 or 2 Oxygen O2 sensors codes. I find it strange that both, (2) different sensors would go out at the same time?
Also I had just filled up the Gas Tank and it did overflow top off a bit. I searched the Web and saw that there's thought that the EVAP Canister purge valve can also code these due to overflow gas while refueling.
I also had cleaned the Air Intake filter the same day before this happened.
The car is idling a little shaky, and seems a bit sluggish while driving at low RPM's. I have disconnected the battery a few time to clear the codes. At start up it gone but comes back each time after a 1/2 mile or so.
Anyone had this problem or know what to do? Thanks.
