footballcoach
Looking for a Gen II center console lid--any color. PM me.
			On a side note, the cover of my console (the cushion-y, upholstered part) seems to have some "spring" or "give" in the area closest to the spring/hinge. That is, it gives to downward pressure, about a 1/4 to 1/2 an inch when pressed down. I must say that tension wise, it's okay...it pushes upward (toward the roof of the car) when downward pressure is relieved. Is this normal or no?
1LoudLS: Yes. The latch is broken.
Don't waste your time thinking you can simply pull the fabric off and attach it to another newer arm-rest. I've been down that path, and it doesn't work. Very poor engineering on Lincolns part designing these arm-rests.
Thanks.
Izzy: thanks for the links.
