freshkid87
- Joined
- Mar 4, 2014
- Messages
- 47
- Reaction score
- 0
wish it were that simple - tried another working (stock lincoln) amp - no dice. My current theory is that the remote turn on signal isn't coming from the stock head unit...
... There's no real way to test the output of the head unit AFAIK other than the system self test - no codes thrown...
You are over complicating it.
Turn the radio on.
Measure the voltage between the amp turn-on signal (at the sub amp) and ground. If I remember correctly, it will be a little over 7 volts. If it's less than 6 volts, it's the problem.
naw ,, i miss my rear speakers in the back working, my car sounds like ass crack right now
