Yesterday; my Lincoln LS interior illuminating lighting would not deem while car was on.
I tried the dimmer; this did not help. I also tried mobilizing the door latch to see if it was stuck; this did not solve the issue.
I also noted that the low beam headlights were not working ( the high beams were). I checked the relays in the trunk and firmly positioned them; not sure if this solved my issue with the low beams; but the high beam light indicator is no longer lit.
Also the radio/CD player and clock have not been working... is this a relay problem?
Thank you in advance for your assistance,
Redeemed7
Redeemed7
