UltimateLS
Hey, I have 2005 LS and would like to add an Aux hook up to my factory Nav... Any good websites for getting this part. Also wanting to change out factory amp. Want to know what connections i need for that.
FRD03-AUX or FRD03-AUX/S
With the THX, you should need the AUX/S. I also heard that the 2005 and 2006 THX systems are different and that the plain AUX version may work on the 2005. Only the AUX/S will work on the 2006.
Of course, PIE has also been bought out. Not likely they will make some of these products anymore.
How many amps it has?*
the factory amp doesn't have any connections that you can use. to replace, you will need to get an amp kit and a Line Output Converter and wire it in.The I ones the the 6*9 hook up too
For 6*9 in the rear
