Ranger31
Okay, I bought my 2005 LS this past Saturday (v-6). Bad hub bearing assembly, and No A/C. Hub bearing, no problem. 30 minutes, and it was all fixed. The A/C is a whole different story. I read a lot on here over the weekend, and decided DCCV. spent the 149.00 and bought a new one. installed, and no difference. (warm air). There is no power going to the compressor. I bought a new Relay, the fuse was fine, but I replaced it anyway, no change. I checked all the DATC fuses, all fine. I ran the DATC self test, and came up with the following. 12-65 Cold air bypass door actuator, 1262 - defrost door actuator circuit failure, and 1242 - air inlet door circuit failure.
Now - when I change locations, i.e. a/c - def - heat, etc. it changes perfectly. At the relay location under the hood, I have two terminals that do have power, and using a jumper I can get the a/c clutch to engage. But there is no power going through the relay to the a/c compressor.
(I'm stumped)..... I absolutely cannot afford to spend a grand at an automotive shop to get the a/c working, but living in Florida. I need a/c. I really like the car, and I want to keep it, but i'm an old fart and need a/c.
Thanks. kinda long I know. but I wanted to provide as much info as I could.
