Mechanicboy
So I was going to use the search function but apparently it doesn't let you just search the LS forum so here it goes.
I recently had a no start problem with my LS. I found out I didn't have any fuel pressure at the schrader valve. I thought it might have been low fuel so I added a few gallons to the tank put still no fuel pressure and I couldn't hear the pump trying to prime either. I traced it to a blown fuel pump fuse in the trunk. I didn't have any spares so I pulled a 30amp fuse from an un-needed accessory and after a few key turns and attempts to start fuel pressure returned and the car started. It ran fine the rest of the day.
A returned to the car a few days later and same problem, no start, no fuel pressure. This time the fuse was good. My thought is that the fuel pump is shorting out internally.
What are the brands of fuel pump that are good and bad?
Edit, found this thanks to google: http://www.lincolnvscadillac.com/forum/showthread.php?70490-rear-seat-removal
