antonio fuller
I have a 2006 and need to install a double din. I have done this on a first gen before , but the middle console is not the same on the second gen
On my 2003 I had started by removing the 3 Star bolts that hold the armrest center storage cover in place. Then I slide a butter knife in between the edge of the storage cavity and the outside of the console to pull the storage cavity out. ...
I'm installing a Alpine ina-w910. Lincoln used alpine systems best to stay in the family in my opinion
They also used Pioneer for the THX navigation. They have also used other brands for the radios.
Audiophile is just a term for "high quality audio" not always used properly lol. I wouldn't really consider the system an audiophile system but hey, its better than my 95 bronco.My 03 has the audiophile 6 disc changer. It bangs both highs and bass. Is audiophile in the Alpine family? I keep seeing ppl say it's alpine.
Top part is vent message center controls, pops out very easily with two soft pry tools. can disconnect once out to get it out of your way w/o causing problems. Next gently pry up trim piece around shifter (black and silver trim on it is one piece). Next pop out your climate controls with your fingers from the bottom. May seem a little difficult but will come out. Then remove ashtray/outlet portion, either 2 or 4 bolts on top and bottom (I forget). After those are out you will have 4 bolts for your radio, 2 on top, 2 on the bottom, pull it out and unplug the cluster f&$% of wires and you should be good to go! You might need to grind down pegs on top of climate controls to fit in your dash kit but wait to see. Also spend more than a minute to find your dash kit. Some of them are garbage, can't recommend which one as I went single DIN from my THX system. Good luck man, hopefully your wiring isnt crazy like mine was!
My owners manual states 3 different types of system depending on the package. Basic, audiophile, and thx which is the navigation unit. Mine says it's audiophile 6 disc changer. Idk just curious. It's definitely a high quality system with great output.
Just got to get the right wire harness no problem very easy
