I have a 2006 Lincoln LS Sport (3.9L, V8) with 131,000 miles on it. The car is displaying classic symptoms of the solenoid assembly going bad. A few write ups in here says the solenoid can be replaced and it's not too difficult. And I saw a nice detailed write up on how to remove it on an 04 LS (but he removed the tranny). I'm not experienced but I can follow directions and I am patient. However dropping the transmission was not an option in my garage.
I borrowed a floor jack and 2 more jack stands and got under there. Removed the pan. Fluid had some wear on it but was not bad. Not a shred of metal shavings in the pan or on the magnet. I removed the filter. Got to the solenoid with no problem.
There was no reverse pressure switch to remove, nor a bottom plate. I removed the screws with no problem. It's then I discover the connector comes down through the bore hole into the solenoid. I spent hours trying to get my hand in the very small void above the bore hole and solenoid with no luck. I gave up as I ran out of time this past weekend and had to put everything back together (with a new filter and a new drain plug).
I read the service manual for solenoid replacement on the deneau site and it specifically said to lift up on the solenoid while removing the connector.
It seems impossible to do this without removing the transmission for access. A
Am I missing something very fundamental? Is there a trick to it? Or does the transmission have to be removed on the 06 make of the LS?
Anyone who has successfully replaced this is welcome to offer their thoughts.
Thanks,
Dylmadbry
Thanks,
Dylmadbry
