what year M8?
It is a 95
The bulb is burned out on turning light. Found one attachment under the headlight adjusting panel. Suspect I have to pull fender liner to get to the rest. Am I correct?
Thanks,
Joe
Remove screw from light on the outer lower corner by the bottom of orange part, remove 11mm? nut from access hole in rad cover, carefully pull light away enough to slide out of the eyebrow trim, unplug connector, change bulb(s) and reverse process.
Thanks for the help. I can now see where I am turning! Didn't know about the little screw hiding in the back. Thought I'd have to get under the fender liner. Now the only problem I have is to see where I am going when driving at night. Know of any headlight improvements?
Joe
did you mean these? on C/L ?See if these are still availible if your chrome I'd shot and ask the guy condition(they look new) and if he ships .
Then buy an hid kit for them
