G-RELL
FULLY DIPPED LS
So this has been going on for awhile. A few times a day, my battery light and check charging message will come up...honestly, It's been doing it for years. I always thought it was failing alternator or battery, and have been waiting to come out to a dead car at some point.... But to this date nothing! I have replaced the battery (with a motorcraft from the dealer), but other then that, it runs and charges fine. my system is setup for running around 800rms but usually dont have it that loud... but the warning started long before i put the system in. I installed a voltage gauge with the system and run 13.5V to 14.0 constantly. maybe a drop here and there at a light and the sub hitting, but never a constant drop... and this usually never triggers the warning... I'll get more under acceleration, then at a stop!
The light will come on at any point, there is no pattern to when it goes off. cruising on the highway, under acceleration, sitting while running... it will go off at any time, any gear, any RPM, and any voltage my gauge says...
Someone (please) give me a list of things to check..
The battery is a new and the alt (as far as i know) is original.
