D
Deleted member 20330
Guest
I'm going to use the Prestone Flush N' Fill Kit.
I'm not going to cut the heater inlet host as described in the Prestone instructions. I'm going to disconnect the heater inlet hose from the engine, temporarily attach the T-connector at the end and then connect a small piece of 3/4" hose to the T-connector and engine. After the flush is done, I'll remove the T-connector and small piece of hose and reattach the heater inlet hose to the engine.
I just need to confirm if the heater inlet hose (pictured below) is the one on top with the hose clamp tool ?
