coalburner
What is required to install an '04 mach 1 engine into my '97 LSC? (and have it work)
i thought the c heads had different exhaust ports than the b's
I use all C head mustang headers on my B heads, so go right on.i thought the c heads had different exhaust ports than the b's
I hear the 5.4 engines had a taller block height so you may have hood interference problems?
Huh? Mach 1 is not 5.4?
The mach1's still have crappy rods and pistons. Also the autos have cast crank too.what would you gain with a mach 1 motor over a lincoln one?
yes you would get better internals for power adders and a little better cams. but after that the motors are about the same. with a few bolt on's they can make the same power.
B heads actually flow better than C heads. a early cobra intake flows about the same as the later ones.
i really don't know a lot about motor specs so i am probably wrong. but in my research on them unless you have a mach motor laying around or can get one cheap i don't really see a advantage to the mach motor over a lincoln one.
well the 04 mach 1 is rated at 310/335. compared to the 280/280 for the lincoln. so something changed for the better.
mach 1 has
better intake, easily bolted on lincoln.
different tune, easily done.
mach 1 has
the mach probably has a little better cams and better flowing exhaust manifolds and exhaust.
you can bolt on the manifolds and the exhaust to the lincoln.
upgrading the cams would be EXPENSIVE so i would pass on that mod.
i don't mean to sound like the mach 1 motor is junk. it isn't. it's a very good motor.
but dollar for dollar you would be much better off upgrading the lincoln motor with bolt on's than spending the cash and time installing a mach 1 motor.
now if your lincoln motor is dead. installing the mach 1 motor is a good upgrade over the stock lincoln motor.
C head, Lincoln is B head so intake is not a simple bolt on.
C heads give you boost options that B heads don't enjoy.
If your building a engine its worth your time to consider a C head engine.
A good B head engine for a simple D/D swap is getting hard to find.
you are correct that a C head cobra intake will not bolt to B heads.
there are B heads cobra intakes for around the same price as a C head cobra/ mach 1 intake.
yes boost is easily available for C heads. i am in the process of collecting parts for a boosted C head motor for my 97 base mark myself.
all i was trying to point out is bolting in a mach motor isn't the best economic choice to make more power in a mark.
you can add a few bolt on's and make about the same power with a lincoln motor as you can with a mach motor for about 1/2 the cost.
now if your lincoln motor is dead it's worth the look at building a C headed motor to replace it.
